Coolant problem with W210
Guest slambert
Hi everybody.
I am Danish, my Norwegian is not that great in writing, so I hope that some one will answer me even though I am Danish :D
The problem is that I am loosing about 1 litre of coolant for every 1000.0km
The sparkplugs looks fine, not white stuff on them. There is no coolant leaking from what I can see, at least nothing to see underneath the car. The exhaust looks fine, no white smoke coming. The oil is nice and clean.
The floor in the car is dry, the frontwindow is not greesed from a leaking colant system.
As you can see I have a problem, and I am lost now, I have no idea what it is. If anyone has an idea about this then please reply, I am getting more and more desperate!
You can answer in Norwegian, no problem as I can read and speak it fairly well. Thanks for taking the time!
Regards,
K. Fab
Guest GammelGul
Det er heller ikke noe problem å skrive på dansk. Vi forstår det meget godt her oppe i bjergene. :wink:
Guest slambert
Hej Olav,
Det lyder godt, jeg skal nok skrive på dansk for fremtiden :D
Hilsen,
K. Fab
Har du sjekket vannpumpa??
Hvis den lekker så vil du ikke se lekkasje under bilen men det er vann rett under pumpa...
Det er ofte den som gir et forbruk av vann men ingen synlige feil ved eksos, motoroljen eller lekkasje...
Sjekk denne og gi tilbakemelding..... :P
Guest slambert
Hej Frode,
Det skal jeg nok checke, tak for hjælpen!
Jeg kommer bilen på liften en af de næste par dage, så må vi se hvad der sker.
Tak igen!
Hilsen,
K.Fab
