Her er da min 86 model s124 300 td
Kjøpt på innpuls i mai 2007
Slik så den ut da:
Motorbytte:
Montering av div utstyr/reingjering:
Slik va den juli 2008:
august 08, rådyr i veien:
Slik ser den ut no:
  • 8 months later...
  • Replies 139
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Her er utstyrs lista på bilen min :)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
240 outside temperature indicator (с 01.03.1982)
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
444 tempomat (cruise control) and airbag (с 01.02.1980 по 31.10.1993)
470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993)
532 automatic antenna without radio set (с 01.01.1963)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
550 trailer coupling (с 01.03.1965)
575 front folding armrest and right front seat with seat height adjustment
front folding armrest and headrest, left (с 01.04.1970)
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
640 aluminium disc wheels with radial-ply tires (с 01.10.1969 по 31.12.1989)
682 fire extinguisher (с 01.04.1970)
812 rear-mounted loudspeaker (с 01.11.1974)
844 folding seat bench in loading compartment, reverse to direction of travel (с 01.10.1977)
873 seat heater for left and right front seats (с 01.02.1984)
I tilleg er de montert:
Høytsittende bremselys
Hellakerte små side speil
Føtbrønnlys framme og bak
Nøttetre i dasjen
Sacco planker
Lakkerte fangere
Klarglass hovedlys og blinkers med parklys
Sportline fjører
R-clik fjernstyrt sentralås
Nye/ombygde fram seter fra 92 mod sportline, fører el memory. pass el
4 el vindu
2 el speil
12 volt utak i bagasjerom
Lastsikrings kroker
Div stereo
Ps2 med skjermer i nakkestøtter og dasjbord
DVD spiller
Klarglass baklykter
  • 1 year later...
Montering av lcd og ps2
Slik kan en setebryter se ut :D
Ny kommer,men har ikkje el nettet til memory setet,det må bygges.
Fikk og sett inn at brannsløkker i dag
Frå påska, kl kvart på 6 skjærtorsdagsmorgen sprakk ventilen til nivåreguleringa.
Dette resulterte til 2 utslitte bakdekk og en del timer skruing i påska.
På besøk med broderen i Volda :D
Sommar dekk å nyvaska 8)
  • 2 months later...
  • 3 weeks later...
