Har bilen din utstyrskode 228?
Jeg hadde ikke fjernstyring på min, men etter litt sjekking fant jeg ut at den var levert med kode 228 så da var den tilrettelagt for fjernkontroll.
Uansett: Bilen din har en Eberspacher, ikke Webasto, og jeg har komplett nytt kit for fjernstyring (trenger både signalmodul i bilen (hvis du ikke har 228) pluss selve fjernstyringa, og det har jeg) liggende et sted. Om du er interessert, kan jeg se om jeg finner det.
Hei, her er info om bilen min:
Parameter Value
423 No code designation available
474 No code designation available
581 No code designation available
9197 OBSIDIAN BLACK METALLIC MB 9197 PAINT
926 No code designation available
AC7 AXLE RATIO I = 3.273
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
CL2 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
CM2 BUMPER AND DETACHABLE PARTS PAINTED VEHICLE COLOR
E07 HILL-START ASSIST
EL9 2-WAY SPEAKER AT FRONT AND REAR
EN0 RADIO SOUND 5
ES1 12 V SOCKET PASSENGER COMPARTMENT
EZ8 PARKTRONIC
F61 INSIDE REARVIEW MIRROR
F64 ELECTRICALLY FOLDING OUTSIDE MIRROR
F66 LOCKABLE GLOVE COMPARTMENT
F69 ELECT.ADJ.& HEAT.OUTSIDE MIRR. W/INTEG. TURN SIGN.
FF1 CENTER CONSOLE WITH STOWAGE COMPARTMENT
FS5 ILLUMINATED MIRRORS FOR SUN VISORS
FZ8 CONVENIENCE OPENING/CLOSING W. INFRARED REM.CONTRL
G40 AUTOMATIC TRANSMISSION
H00 HOT/COLD AIR DUCT TO PASSENGER COMP.
H12 HOT WATER ADDITIONAL HEATER
H13 ADDITIONAL HEAT EXCHANGER, REAR
H15 SEAT HEATER FOR FRONT PASSENGER
H16 SEAT HEATER FOR DRIVER
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
HF2 POLLEN FILTER
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
HI1 CLIMATE ZONE 1 (COLD/COMFORT)
HZ0 ELECTRIC HEATER BOOSTER
IL1 INLAND (GERMANY)
J56 SEAT BELT WARN. SYS. F. DRIVER + FRONT PASS. SEAT
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JA5 LIGHT AND RAIN SENSOR
JC2 SOFTTOUCH COCKPIT
KA1 PARTICLE FILTER
LB9 EXIT LAMPS
LD0 OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS
LD5 ADDITIONAL INTERIOR LAMP IN PASSENGER COMPARTMENT
M40 ALTERNATOR 14 V / 200 A
MC3 ENGINE OM646 DE22LA 110KW (150HP) 3800RPM
MF4 LOW-EMISSION VEHICLE EURO 4 GR. III
Q22 TRAILER HITCH WITH NON-REMOVABLE BALL HEAD
RF9 TIRE MANUFACTURER GOODYEAR (90)
RG7 TYRES 225/55 R17
RL8 LIGHT-ALLOY WHEELS 7JX 17
RM4 COMFORT TYRES
RR7 TIREFIT
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
T70 CHILD SAFETY LOCK ON DOORS IN PASS. COMP.
UR1 SEAT RAIL SYSTEM WITH QUICK COUPLING
US6 SINGLE SEAT 1. ROW LEFT
US7 SINGLE SEAT 1. ROW RIGHT
US8 SINGLE SEAT 2. ROW LEFT
US9 SINGLE SEAT 2. ROW RIGHT
V33 CARPET IN REAR
V36 HEADLINER
V44 CARPET IN FRONT VEHICLE INTERIOR
VH1 GRAB HANDLES IN REAR
VP1 TREND EQUIPMENT LINE
VU5 LEON ORION GRAY FABRIC
W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W32 ELETRIC VENT WINDOW PASSENGER COMPARTMENT
W65 TAILGATE
W70 COLOR GLAZING IN REAR, BLACK GLASS
W78 LIFTGATE/REAR-END DOOR WINDOW W/ WIPER+WASHER SYS.
X30 REGISTRATION CERTIFICATE, PART II
XA0 WEIGHT VARIANT 2,770 KG (1,470/1,470)
Y10 FIRST AID BAG
Y44 HAZARD WARNING TRIANGLE
YE2 FOLDING TABLE
YE5 ASH TRAY AND DRINKS HOLDER IN PASS. COMP.
Z42 APPROVAL AS PASSENGER CAR
ZG2 PERMANENT ALL-WHEEL DRIVE
ZP5 ACTIVITY PACKAGE
Fikk en mail fra eber som skrev at siden bilen hadde canbus og tidsstyring så hadde de ikke noe fjernkontroll til den dessverre :-(
Skulle så gjerne hatt muligheten til å starte den ved behov utenom tidsstyringen, men må nok bare gå ut til bilen å starte den manuelt der.
forstod det var en bryter man kunne trykke på for å starte den manuelt.
Skal gå dette, men du må ha signalmodulen som skal monteres i bilen i tillegg til fjernkontroll.
Skal sjekke garasjen i morgen og se hva jeg egentlig har. Kjøpte det i 2013, men det blei bare liggende.
hey hey, da snakker vi, er det da en modul som monteres i bilen også er det en fjernkontroll til nøkkelknippet?
Hadde vært veldig kjekt å fått det på plass, jeg er lam i halve kroppen etter hjerneslag og går dårlig, dessuten gjør kulda meg spastisk, så det er ikke lengre bare å sprette ut å skru på varmen ;-)
Det stemmer ja. Signalmodulen i bilen har jeg et sted. Monteringsanvisning kanskje også. Litt usikker på fjernkontrollen, men tror jeg har den også. Kjøpte det av MBenznl i Nederland. Dette er det samme som er montert i bilene originalt.
Jeg kjøper ikke lenger en bil uten fjernstyrt varmer :) Blir helt bortskjemt!
Skal prøve
Skal prøve
Supert om jeg får kjøpt det av deg om du finner det, sender deg epost adressen på pivat melding :-)
  • 6 years later...
