Jonas94 Posted December 14, 2015 Posted December 14, 2015 Noen som vet av en mekanisk pumpe man kan sette rett på OM604? Er en del som er plaget med at sensor i pumpa går på de. Evt my jobb å reparere? Quote
Jonas94 Posted December 14, 2015 Author Posted December 14, 2015 O-ring som kan byttes? https://en.wikipedia.org/wiki/Mercedes-Benz_OM604_engine The seals of the Lucas injection pumps become brittle over time and leak. Since the replacement of the entire injection pump is very expensive, a repair kit is offered in which the affected seals are replaced. Quote
