Hei.
Min første post her på forumet.
Jeg skal ta service på min w204 10mod. Er det noen som vet hva de forskjellige servicene inneholder? F.eks service 2, service 3 og service 15?
ImageUploadedByTapatalk1446915895.458700.thumb.jpg.6630a1b1e51f3983ec08f119ed6f96b8.jpg
  • 2 months later...
Da bør forhandleren kunne gi deg oversikten over hva de ulike innebærer.
Ellers kan jeg tenke meg at det er ganske likt som for andre modeller..
Hentet fra et britisk MB-forum, gjelder E-klasse.
http://www.mbclub.co.uk/forums/engine/26143-help-decode-assyst-plus.html
1 = check brake pads and disks
2 = (every 2 years/30k km) check trailer hitch
3 = (every 2 years/60k km) check poly v belt, replace compressor poly v-belt, replace air clieaner insert,turn air filter element by 180 degrees (only on 1st service 3)
4 = every 60k km / 2 years option 580 aircon - change filter
5 = every 60k km / 2 years option 581 aircon - change all 3 filters
6 = every 2 years bodywork check, underside check, replace brake fluid
7 = every 5 years clean sunroof mech
8 = every 3 years clean panaramic roof mech
9 = every 80k km / 4 years air cleaner insert (most engines), fuel filter, spark plugs on engine 271
10 = every 100k km / 4 years, spark plugs on engine 112/113/272
11 = ebery 120k / 4 years, replace air cleaner insert engine 646/647/648
12 = evert 250k / 15 years, fuel filter (engines 112/113/271/272), replace coolant
20 = 60000 km transfer case oil change on 4 matic, auto transmission oil and filter change
13 = at each service, engine oil and filter change
14 = brake fluid level, washer fluid level, check engine hood latch, lots of interior checks, horn, wipers, etc etc, check tyres, trunk lighting, battery
15 = same as 14 + check all visible parts for leaks, check pwoer stearing, replace spark plugs on engine 271 and fuel filter on engine 646 with code 921 (operation with Rape seed oil !!) or VOME (vegetable oil methyl ester)
check wheels and brakes, and all body work and lights and couplings etc
