Enebakk Posted November 3, 2006 Posted November 3, 2006 Her er litt bilder og info om bilen. VIN --------------------------- Model 300 TE Chassis ---------------------- Engine 103983 12 119283 Transmission 722320 03 094360 Order 0 8 220 00197 Approx. year 1988 Lights HELLA Cab 02775 Dealer Hannover branch (220) Interior fabric blue (072) Paint 147 arctic white (T) (с 01.01.1985 по 31.12.1993) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 228 auxiliary heater auxiliary heater (с 01.11.1974) auxiliary heater (only provision for installation in w 210) 240 outside temperature indicator (с 01.03.1982) 245 on-board computer (с 01.09.1983) 260 elimination of model designation on rear lid (с 01.05.1968) 420 automatic transmission, floor shift (с 01.01.1963) 444 tempomat (cruise control) and airbag (с 01.02.1980 по 31.10.1993) 534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990) 541 double roller blind used as luggage and passenger guard (с 01.01.1980) 553 trailer coupling and anti-theft warning system (с 01.11.1978) 581 automatic climate control (с 01.01.1977) 611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978) 620 emission control system vehicles with catalyst technique (с 01.03.1985) 682 fire extinguisher (с 01.04.1970) 724 cargo anchorage (с 01.04.1979) 812 rear-mounted loudspeaker (с 01.11.1974) Litt dårlige bilder men de er tatt med mobil kamra
Olav Posted November 4, 2006 Posted November 4, 2006 Tøff vogn. Spesielt utstyrt med kjørecomputer, klimaautomatikk og motor/kupévarmer, men ikke midtarmlene og el-vinduer. Six-packen foran passasjersætet går jeg ut fra er uoriginalt.
CHARLIE Posted November 4, 2006 Posted November 4, 2006 Utrolig mye snadder-utstyr i denne Enebakk!! Men hva slags dimensjoner er det på dekk/felg? Tar forhjulene oppi når du kjører i humper eller??
Enebakk Posted November 5, 2006 Author Posted November 5, 2006 Utrolig mye snadder-utstyr i denne Enebakk!! Men hva slags dimensjoner er det på dekk/felg? Tar forhjulene oppi når du kjører i humper eller?? Takk takk. hjulene er 235/40-18 8,5" et35 dem tar litt oppi når jeg kjører hard i svinger/humper ja
Enebakk Posted November 5, 2006 Author Posted November 5, 2006 Tøff vogn. Spesielt utstyrt med kjørecomputer, klimaautomatikk og motor/kupévarmer, men ikke midtarmlene og el-vinduer. Six-packen foran passasjersætet går jeg ut fra er uoriginalt. hehe six-packen ble levert fra Rema den
