500AMM Posted January 5, 2015 Posted January 5, 2015 Hei. Jeg prøvde å søke opp dette temaet uten å finne noe klart svar. Det er altså snakk om å programmere en ny IR-nøkkel, og om man kan omprogrammere en IR-nøkkel fra en annen bil. -a-
Tor Anton Posted January 5, 2015 Posted January 5, 2015 jeg har akkurat linket til en finn annonse på nyere nøkkel,mulig de samme har noe til eldre. Ellers så er ikke dette mulig. jeg søkte på dette ang min vito å "alle" var enige om at dette ikke gikk.
Lassen Posted January 5, 2015 Posted January 5, 2015 Fant dette etter litt søk: "This applies to the circa 95/96 models with the green/red LEDS in the drivers door lock position without the LEDS in the rearview mirror. FIRST and important, best get new batteries for your remote. MERC seem to use 2 varta CR 2025 for the flip key type. Test the key is operating by pressing the button for a couple of seconds, a red light should show at the front of the unit after a slight delay as ANDY said. If you have a digital camera and you view this indicator thro the camera LCD display you should see a white light instantly you press the button since the LCD will pickup the infra red signal. NOW go to the passenger door and make sure the car is locked. 1.point the remote at the lock at a distance of about 12 inches. PRESS the remote for 5 seconds. 2.unlock the door by turning the key in the lock 3. wait 10 seconds then remove the key. 4.repeat 1. for 5 seconds. 5.lock the door with the key wait 10 seconds and remove the key. Your key should now be synchronised with the remote locking and lock/unlock the car. Be deliberate in your actions. check which way to turn the key to lock unlock the car before starting. Take time between steps. this worked for me Other synchronising methods may work. I tried several before the one I detailed worked. best to try it several times with slight variations to the timing till it works. GOOD LUCK." I denne tråden: http://www.mbclub.co.uk/forums/electronics/26218-96-w-s-124-e200-remote-central-locking.html
Tor Anton Posted January 5, 2015 Posted January 5, 2015 Er ikke dette for å "friske"opp igjen den org.nøkkelen?
Lassen Posted January 5, 2015 Posted January 5, 2015 Er ikke dette for å "friske"opp igjen den org.nøkkelen? Vet ikke, enkleste er vel kanskje å høre med BOS
Tor Anton Posted January 5, 2015 Posted January 5, 2015 Er ikke dette for å "friske"opp igjen den org.nøkkelen? Vet ikke, enkleste er vel kanskje å høre med BOS Det har jeg gjort. De sier du IKKE kan programere en nøkkel fra en bil til å passe en annen. Du må kjøpe en fabrikkny nøkkel.
