MartinBo Posted August 1, 2012 Posted August 1, 2012 Her er litt om bilen min: W210 E420 1997 US-edition med 180.000km bak seg fin WDBJF72F9VA291725 vin WDB2100721A291725 whc WDB chassbm 210072 chass_ident 1A291725 type 210 subbm1 072 engine 119985 02 014995 front_axle2 BE1692T1099097815613 interior 201A lights HELLA model_idx 2 order_num1 0770475115 paint1 744 retarder 2 961113 transmission 722625 00 185465 vin_dc JF72F9VA291725 Interiorleather "nappa" two-color anthracite+anthracite (251) 744 brilliant silver metallic OPTIONS 213 PARAMETER STEERING 231 GARAGEDOOR OPENER 236 SPECIAL LIGHT WIRING FOR NORWAY AND SWEDEN 242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY 249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR 251 RADIO MB - EXQUISIT - USA 260 ELIMINATION OF MODEL DESIGNATION ON REAR LID 265 LINES-NO.PLATE DISCONTINUED 275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR) 295 CURTAINS FOR LEFT AND RIGHT REAR DOOR WINDOWS 309 CUP HOLDER 400 FOLDING ARMREST IN THE REAR 401 VENTILATED AND HEATED FRONT SEATS 404 LEFT FRONT SEAT WITH MULTIPLE CONTOUR BACKREST 405 RIGHT FRONT SEAT WITH MULTIPLE CONTOUR BACKREST 414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION 423 AUTOMATIC TRANSMISSION 5-SPEED 431 3-POINT SEAT BELT REAR CENTER 461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND 494 VERSION FOR USA 500 OUTSIDE REAR VIEW MIRROR LEFT AND RIGHT, FOLDING 540 ROLLER BLIND, ELECTRIC FOR REAR WINDOW 524 PAINTWORK - PRESERVATION 543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE- 551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM 570 STOWAGE BOX FRONT WITH ARMREST 581 AUTOMATIC CLIMATE CONTROL 600 HEADLAMPS - CLEANING EQUIPMENT 611 COURTESY LAMS FOR FRONT AND REAR DOORS 630 WARNING TRIANGLE 634 DELETION - FIRST AID KIT 659 LIGHT ALLOY WHEELS, 5-HOLE 668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK 673 BATTERY WITH INCREASED CAPACITY 679 SPARE WHEEL 772 AMG STYLING PACKAGE (FRONT SPOILER, SIDE SKIRTS AND REAR APRON) 777 TAIL MUFFLER IN AMG DESIGN 791 AMG ONE PIECE 18" ALL AROUND 807 AEJ 06/1/M/X 810 SOUND SYSTEM (BOSE) 872 SEAT HEATER FOR LEFT AND RIGHT REAR SEATS 873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS 875 HEATED SCREEN WASH SYSTEM 955 EQUIPMENT PACKAGE ELEGANCE 987 BATTERY ISOLATION SWITCH FOR SHIPMENT VEHICLES 200A LEATHER 744 DARK BLUE SOFT TOP FABRIC 5010 251 NAPPA TWO-COLOR ANTHRACITE + ANTHRACITE rustfri (kryss i taket!) Det som er gjort de siste årene: Begge forskjermer byttet Bagasjelokk byttet Førerdør byttet Optikklykter foran og klarglass i fangeren samt ledlykter bak. Treratt, trehåndtak i dørene og noe annet rask. Var på Bergs automatservice igår og fikk kassa erklært i toppstand!! Det som skal gjøres i august: Bytte mye av foringer i for- og bakstilling hos Klaus i Flensburg, i den forbindelse sette på Bilstein Sprint og 35mm H/R fjærer. Overhaling av motoren. AMG originale 18" style II er bestilt og kommer på i slutten av august. Bytte tacho til euro-utgave for å slippe miles-speedometer. Bestilt på ebay.de for 140euro inkl frakt Skifte av automatoljen. Installere 2-din spiller Installere elektrisk rollo i bakruten Quote
MartinBo Posted August 1, 2012 Author Posted August 1, 2012 Flere bilder W210 E 420 Antall sylindre 8 (V) Antall ventiler 32 Boring/slaglengde 92,0 / 78,9 mm Slagvolum 4196 cm3 Kompresjon 11,0 Effekt 279 HK ved 5700 o./min. Dreiemoment 400 Nm ved 3900 o./min. Drivstofftank 80 liter Felger 7 1/2 J x 16 H 2 Dekk 215/55 R 16 93 W Akselerasjon 0-100 km/t 7,0 sekunder Topphastighet 250 km/t Forbruk per 10 km -ved 90 km/t 0,79 liter -ved 120 km/t 0,94 liter -ved bykjøring 1,44 liter Transmisjon 5-trinns elektronisk styrt automatgir Akselavstand 283,3 cm Sporvidde foran / bak 153,4 / 152,8 cm; Avantgarde: 154,0 / 153,1 cm Lengde 479,5 cm Bredde 179,9 cm Høyde 143,9 cm; Avantgarde: 141,8 cm Snudiameter 11,34 meter Totalvekt 2220 kg Egenvekt 1690 kg (Iflg. EG 92/21: med fører (68 kg), 7 kg bagasje, 90% drivstoff) Copyright © Michael Nielsen Quote
tommern57 Posted August 4, 2012 Posted August 4, 2012 Med 235/40-18 og senk framme, kan det lønne seg å kikke litt på slutten av tråden om min pre-facelift 210. http://www.mbentusiastklubb.no/smf/index.php?topic=15941.0 Trur ikke eibach/bilstein kombo er noe dårligere, heller tvert om Quote
MartinBo Posted August 6, 2012 Author Posted August 6, 2012 Ja ok skjønner takk for tipset. Vet du om skjermene er bredere på E50/E55 enn vanlig W210 også forresten? Quote
tommern57 Posted August 6, 2012 Posted August 6, 2012 Trur det er det samma, men AMG utstyrte biler har vel litt mer valsing for å legge leppa litt mer. Hvis du lar hjula stå rett fram, og står foran bilen, vil du se at forskjerm/støtfanger på en måte buer inn under bilen. Min subba i dumper/sving kombo med 235 dekk i 17 og 18toms. Og det gjorde meg forbanna siden jeg hadde nye framskjermer. Quote
MartinBo Posted August 6, 2012 Author Posted August 6, 2012 Auda! Det skjønner jeg var irriterende. Vi får bare se. Angående tikkingen som har vært i bilen min siden jeg kjøpte den fikk forresten tak i oljerør i aluminium til kamakselen fra en fyr på Benzworld. De kostet 225usd pr stk + frakt. Noen andre som vil ha? M119 hadde metalrør for oljing av kamakselen fram til 92/93. Etter det gikk de over til gummi. Gummirørene går istykker og forårsaker tikking. Med bytte av alle til alu er man kvitt problemet for godt. All tikking er helt borte nå!! Tusen takk til Arnt 500AMM for all assistanse så langt Quote
MartinBo Posted August 22, 2012 Author Posted August 22, 2012 Bestilte E50 AMG bodykit og eksos fra Steve i Nederland akkurat, kommer bilder når dette er på uti sept en dag! Yes!! Kjempehjelp fra Sven Håkon, tusen takk!! Igår skrapte jeg av den gule malingen på viserne i instrumenthuset og malte dem hvite, det ble kult! Kromringer fra autoroyal satt prikken over ien. Quote
MartinBo Posted August 24, 2012 Author Posted August 24, 2012 Xenon ombygging herved gjennomført! Det ble lyst og fint ja. Byttet parklyspærene med ledpærer fra Osram på 4000kelvin. De er et hår mer gul enn 4300kelvin xenon pærene, men MYE bedre enn de som satt i. Bilder kommer gutta. Begynner å bli kjip den tråden her, med bare tekst og copy paste bilder :-/ Quote
Joakim Borkner Posted August 27, 2012 Posted August 27, 2012 Kanon den her Misunner motoren i den! Du får legge ut bilde av instrumentpanelet ditt. Ser hvert fall pent ut på bildet du har lagt ut, så får kansje kjøpe inn noen krom ringer å male litt . Forresten var det lett å feste ringene så de henger godt? Quote
MartinBo Posted August 27, 2012 Author Posted August 27, 2012 ringene sitter som støpt de, tar 5min å installere. Quote
MartinBo Posted August 28, 2012 Author Posted August 28, 2012 E55 ratt innkjøpt. Gleder meg til å poste bilder! http://www.ebay.com/itm/160873208537?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_783wt_961 Quote
MartinBo Posted August 30, 2012 Author Posted August 30, 2012 beklager veldig dårlige mobil bilder, men, men here goes nothing: hvitmalte visere og chromeringer. Har kjøpt alu-ringer allerede og tror det blir bedre enn dette: Pioneer F40BT er Top of the line ihvertfall. Gleder meg til å prøve den. Her i nyinnkjøpt ramme og lønneplate. ble fint med originale pedaler fra SLK R107 (brems og fotbrekk) og SL R230(gasspedal) da begynner jeg å komme igang med ombygging fra valnøtt til fugleøyelønn. Mesteparten er brukt fra ebay så ble ikke dette så dyrt! de orginale E55 hjulene var i topp stand, men med alle de strøkne AMG bilene med 20" og 22" her i Tyskland ble 18" liksom ikke helt vasst nok. (disse blir vel vinterhjulene og så kommer det på 19" til sommern) Quote
MartinBo Posted August 30, 2012 Author Posted August 30, 2012 Hold on tight for bilder av: AMG E55 ratt fold in speil m/ blink orig. w210 facelft el Rollo bak orig. w210 nappa seter med kjøling foran og varme bak orig. w210 facelift AMG body Kit og eksos Quote
Christoffer Posted August 30, 2012 Posted August 30, 2012 Hei, Lekker 210 med grom motor du har! Original 210 bil med amg styling bør ha originale 18" AMG hjul som du viser bilde av der etter min mening. Noe større føler jeg blir litt "harry" på 210. Quote
MartinBo Posted August 30, 2012 Author Posted August 30, 2012 Hei, Lekker 210 med grom motor du har! Original 210 bil med amg styling bør ha originale 18" AMG hjul som du viser bilde av der etter min mening. Noe større føler jeg blir litt "harry" på 210. Takk for det Chris! Quote
MartinBo Posted September 6, 2012 Author Posted September 6, 2012 5 dager på Klaus & Co i Flensburg ga meg helt nytt understell, Bilstein Sprint og H&R 35mm, motoroverhaling med nye oljerør, motorreim, nye vakumslanger, etc, skifte av olje på girkasse, 2-din spiller installert, mye nytt på bremsene bak og en del nye stag og foringer i for- og bakstilling samt sl og slk pedaler og style 2 AMG 18". Bilstein Sprint og H&R 35mm og felgene hadde jeg med selv, men ellers ble jobben på 45k inkl deler for 2k euro med ca 45 arbeidstimer! Det var billig syns jeg. Bilen kjennes helt ny ut etter den jobben! Jeg har installert nytt E50 AMG ratt og byttet kromskivene på instrumentene med alu-skiver. Her er rollo i bakruten på plass! Nå er jeg i Nürnberg. Her holdt selgeren av det nye Nappainteriøret mitt til. Det va en god tur fra Flens, men vel verdt turen. Det nye interiøret er kun rullet 60k og har kjøling foran, multikontur foran samt varme bak, i tillegg til original brannsluktningsapp. Sammen med Giorgios fra Hellas som solgte meg disse setene installerte vi også kjempefine ledlys i fotbrønnene foran og bak og ledlys i oppbevaringsrommene i dørene. Koblet det opp mot instrumentbelysningen slik at dimmerknappene virker. Quote
MartinBo Posted September 6, 2012 Author Posted September 6, 2012 et skritt nærmere varme i baksetene nå ble det fullt! Innfellbare speil fra facelift er installert, rollo er på, bagasjeromsåpnet var der fra før. De to resterende knappene skrur ledlys i fotbrønner og oppbevaringsrom i dørene av og på. Front kanpp er lysforan og bakerste knappen er lys bak. Pioneer kameraet er på. Koblet reversledningen fra automatnettet til F40BTen og vips så svitsjer den automatisk till ryggekamera når bilen blir satt i revers. Quote
MartinBo Posted September 7, 2012 Author Posted September 7, 2012 Her kom det riktige bildet. Knappene i øvre venstre og høyre hjørnet styrer det hjemmesnekra lysstuket. Poster bildet av det når det er helt ferdig. Quote
Khan1 Posted September 7, 2012 Posted September 7, 2012 Her har du en skikkelig fin w210 med riktig fargekombinasjon, som blir enda bedre med alle oppdateringene du gjør Synes rattet så perfekt ut i denne bilen Bare å stå på Quote
MartinBo Posted September 9, 2012 Author Posted September 9, 2012 Da var bilen ferdig hos Steve!! Quote
tommern57 Posted September 9, 2012 Posted September 9, 2012 Absolutt på rett vei. Blir bra detta Quote
Bjørn Nøvik Eide Posted September 9, 2012 Posted September 9, 2012 Dette ble bra, skal nedover til Steve om 14 dager for div oppgraderinger,så godt du er nede fra bukken :lol: Quote
MartinBo Posted September 9, 2012 Author Posted September 9, 2012 Takk for positiv respons, det hjelper veldig når det svir andre steder Det som står igjen for denne gang: 1) Reparere lekkasje i vakumanlegget til setene 2) Reparere lekkasje i AC-anlegget 3) Lakkere speilhuset på høyre side 4) Installere OEM gardiner i siderutene bak 5) Installere rattmontert fjernkontroll til Navi. MF-ratt gikk dessverre ikke an på V8 ifølge Steve 6) Installere 55watt xenon i fjernlys 7) Installere RIGID D2´s skjult i fangeren og koble opp mot fjernlys. Disse lyser visst minst like sterkt som 55w xenon og tenner umiddelbart. 8. Installere birds eye håndtak i dørene 9) Bygge Led-leselys bak på begge sider. OEM look 10) Bytte til 19" AMG style II felger (evt bytte tilbake hvis det blir for stort) Quote
