Einar Posted May 31, 2010 Posted May 31, 2010 Da ble det en ny TDT på meg, en `93 modell regga i `94. Bilen virket bra teknisk, gått ca 570.000 km, motoren skal etter sigende(fra en tidligere eier) være relativt nyoverhalt(finnes ikke gjennomslag i det hele tatt), men det er en del for å få den ene siden fin, men rust var det ikke så ille for. VIN WDB1241931F287146 Model 300 TD TURBODIESEL Chassis 1241931F287146 Engine 603960 12 051013 Transmission 722357 03 968898 Order 0 3 226 11779 Approx. year 1993 Lights HELLA Wiper BOSCH Dealer Munich branch (226) Interior (cloth) fabric black+anthracite+graphite (001) Paint 744 brilliant silver metallic (с 1991) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 221 left front seat, electrically adjustable (с 01.11.1978) 240 outside temperature indicator (с 01.03.1982) 291 airbag for front passenger airbag for driver and front passenger (с 01.07.1987 по 30.09.1993) airbag for driver and front passenger (if driver airbag standard - then only for passenger) 300 storage box in front tray (с 01.05.1988) 404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995) 440 tempomat (cruise control) (с 01.09.1975) 537 mechanically operated antenna and front loudspeaker - without radio set (с 01.10.1989) 541 double roller blind used as luggage and passenger guard (с 01.01.1980) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970) 591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972) 611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978) 620 emission control system vehicles with catalyst technique (с 01.03.1985) 885 880 - with immobiliser Annonsebildene Det er som dere ser verken takluke eller hengerfeste på bilen, men ellers er det ganske greit, hengerfeste er det stor sjans for at hopper over fra den andre TDT`n Det er litt leie småfeil på den. ABS er overfølsom i lav fart, tips? El-vinduer virker kun når dør foran står oppe, Relè? Noen som vet hvordan det er å flytte trekk osv. over fra sportline skinnsete til standard stoffsete med el-styring? Quote
FrodeS Posted May 31, 2010 Posted May 31, 2010 Grattis. Tror du har fått deg mye bil for pengene. 300Turbodiesel til 30K må være bra. Ulempen er at nå er det enda en som slår meg på "høyeste km" på neste landstreff Da ble det en ny TDT på meg, en `93 modell regga i `94. Vet du om det er byttet interiør i den? Den har faceliftinteriør, men både ordrenummer og "approx year" sier jo 1993. ABS er overfølsom i lav fart, tips? Prøv å bytte "hjernen". Hjelper ikke det, prøv å bytte sensorer. El-vinduer virker kun når dør foran står oppe, Relè? Reléet bakerst i sikringsboksen får signal fra tenning og dør. Begge deler vi skru på strømmen til el.vinduer og litt sånt. Antakelig enten reléet eller styrestrømmen fra tenninga. Noen som vet hvordan det er å flytte trekk osv. over fra sportline skinnsete til standard stoffsete med el-styring? Det går helt fint. Jeg flyttet skinnet fra 500-sete over på rammene til standard stoffsete en gang. Ble helt knall. Fjærene var like harde også, men vil du bytte dem, så slår du dem greit løs med en forlenger uten pipe på. Quote
iNDiANER Posted May 31, 2010 Posted May 31, 2010 Gratulerer med ny bil Einar! Så flott ut denne! Du har jo en del reservedeler til overs nå, så du burde kunne ha bil i mange år fremover her, så sant det ikke skjer deg noe mer uheldig Quote
Einar Posted June 1, 2010 Author Posted June 1, 2010 For komme med en liten bildeupdate da, det ble ikke så gode bilder, men litt ser man da. Har fått montert 3 18" hjul, og bredda ene framskjermen, den siste skjermen og hjulet der for vente til jeg får taki skruene jeg trenger for å montere breddekittet på andre siden, tror det er noen i "plukken" som ikke vet forskjell på 40 mm og 12mm lengde, for det er nemlig motsatt anntal av hva jeg trenger. Men det jeg gjorde ble ganske bra, måtte brette inn kanten på buene bak, de var rett inn og breie merkelig nok, men nå ble det plass. Og til sist... [move]Og nei, den går ikke på bensin... [/move] Quote
Einar Posted June 2, 2010 Author Posted June 2, 2010 Da ble det en ny TDT på meg, en `93 modell regga i `94. Vet du om det er byttet interiør i den? Den har faceliftinteriør, men både ordrenummer og "approx year" sier jo 1993. Jeg tror både interiør og utvendige deler er orginalt, har bare inntrykk av det. Noen som vet hvordan det er å flytte trekk osv. over fra sportline skinnsete til standard stoffsete med el-styring? Det går helt fint. Jeg flyttet skinnet fra 500-sete over på rammene til standard stoffsete en gang. Ble helt knall. Fjærene var like harde også, men vil du bytte dem, så slår du dem greit løs med en forlenger uten pipe på. I bilen står det førersete som er både elektrisk og ortopedisk, hvis jeg skal putte i skinninteriøret vil jeg ha det der og, hvordan sitter disse tingene i setet, greier man å flytte over delene, eller er det lettest å bytte over trekket? Quote
Arne Solhaug Posted June 2, 2010 Posted June 2, 2010 Grattis med ny grombil Einar! Ser frem til flere updates og bilder, Ser bra ut denne Quote
FrodeS Posted June 2, 2010 Posted June 2, 2010 Både interiør og eksteriør er jo 1994. Prøv å få tak på produksjonsdato .. Hvordan luftputegreiene funker vet jeg ikke, men det ble aldri levert på sportline, så der kan du få problemer. Quote
Lorns Stavrum Posted June 2, 2010 Posted June 2, 2010 ABS kan være mye dritt på tann kransen ved følererene foran,ta ut føler og gjør ren tannkransen, mercedes mekaniker som fortalte at det kunne være nok, har det samme på -88 230ce, har ikke fått prøvd det ennå men det blir Quote
Einar Posted June 2, 2010 Author Posted June 2, 2010 ABS er midlertidig fikset ved å koble fra styreenhet. Bilen er `94-modell i vognkort, og bærer ikke preg av å være ombygd. Hvor finner man slike "lapper" på S124, W124 finner man på/ved tanken og slik. Hvor kan jeg finne produksjonsdato? Skal se om det står noen førstegangsregistrering i vognkortet straks. Lurer veldig på hva jeg skal gjøre med interiøret. Trenger noen smådeler fra den gamle her, mens jeg er veldig sugen på skinn, men vil heller ikke kvitte meg med utstyr, og pengene jeg kan få for skinninteriøret er absolutt trengte... Quote
Einar Posted June 2, 2010 Author Posted June 2, 2010 Registrert Første gong: 1994 Registrert første gong i Noreg: 1998-06-22 Merknader i vognkort: Førstegangsreg i Tyskland: 11/4-1994 Quote
Tor Håkon Posted June 3, 2010 Posted June 3, 2010 Hvor finner man slike "lapper" på S124, W124 finner man på/ved tanken og slik. Dørtrekka kanskje? der er det hvertfall på w124. . og på varmeapparatet..? Quote
bska Posted June 3, 2010 Posted June 3, 2010 Tar jeg ikke helt feil står det en dato under dekselet på ABS enheten Alternativt kan du ta ut rådelagrene, står produksjons mnd/år på undersiden av skålene, he he Quote
Einar Posted June 3, 2010 Author Posted June 3, 2010 Alternativt kan du ta ut rådelagrene, står produksjons mnd/år på undersiden av skålene, he he Sant det, får ut å skru... Men motoren er visstnok overhalt, så får meg kanskje en skuffelse da, og finner ut at bilen er en 2008 modell Quote
Einar Posted June 3, 2010 Author Posted June 3, 2010 Kikka etter tempomate-styreenheten i dag, og tror jeg fant den, den heter "014 545 402 32", og er en litt stor boks under rattet. Loddingene ser hele ut, men jeg får gå over de som går til stikket med bolt å se om det hjelper, den er helt død... Forøvrig er CC-enheten merket med 0494, så bilen er vel garantert en `94 modell... Quote
Einar Posted June 7, 2010 Author Posted June 7, 2010 Noen som har innspill og tips ang. tempomaten, den er helt død, virka visst ved nyttår, ECU ser ok ut i loddinger, men gikk over de ved stikket med loddebolten. Bremselysbryter? Tok den ut, målte den, og den fungerte, men fikk ikke 0 ohm motstand i den noen vei, kretsene virka motsatt. Hvilke sikringer går den over, kun den ene som står opplyst? Quote
Einar Posted August 22, 2010 Author Posted August 22, 2010 Får ta en liten update her da, bilen har vel rullet 576 nå, har hatt totalt hjullagerhavari på begge framhjula, har en lekkasje fra ett hydraulikkrør i nivåreguleringa, som igjen er juster alt for høyt, bilen er stump og spretten i baken, mistenker at dette kommer av enten for høyt justert eller gasskuler. Bilen har fått seg 2 nye framdekk nå også. Har også ett fangerprosjekt på gang, spleise en 212-fanger med en 124-fanger, noe som ikke akkurat er perfect fit ettesom ingen mål eller vinkler ser ut til å stemme overens, men vi får se om jeg får det til. Quote
Tor Olav Posted August 23, 2010 Posted August 23, 2010 ta å kikk ein gong til FrodeS, så legger du tilmerke att den bilen er sølvfarget og den som skal bli "most" er bornitt Quote
FrodeS Posted August 23, 2010 Posted August 23, 2010 ta å kikk ein gong til FrodeS, så legger du tilmerke att den bilen er sølvfarget og den som skal bli "most" er bornitt Får skylde på at jeg er litt i tåka her, med langt fremskreden forkjølelse, litt feber og en datter som driver og får tenner Var visst "feil" TDT, detta Quote
Einar Posted August 23, 2010 Author Posted August 23, 2010 LOv å være i tåkeheimen frode, du er ikke aleine... Quote
Einar Posted September 17, 2010 Author Posted September 17, 2010 Og i dag fikk vi en god runde mekking i nøden. På tur til byen merka jeg at bilen begynte å riste litt vel i venstresvinger, stoppa opp og så at det var to knekte hjulbolter, emn reste så ut til å være intakt, så fant ut at jeg fikk prøve å kjøre dit jeg skulle, ettersom jeg var over halvveis, og hadde forlagt hjulvinna hjemme her om dagen. Kom litt lenger så rista den mere og mere og jeg stoppa, fant ut at nå må jeg gjøre noe, tør ikke kjøre videre, en av de tre boltene som selvfølgeli var ved siden a hverandre alle tre var litt løs, leita litrundt i bilen og fant 17mm fast, og der knakk den som var litt løs, fram med jekken, jekke opp, løsne de to gjenværende, hvorav en knakk rimelig fort, og den siste holdt, det var i utgangspunktet en knekt på det hjulet, men å kjøre med 4 er ikke skummelt, så det ble satt på vent. Så hadde jeg kjørt til neste potensielle stoppeplass hadde mest sannsynlig hjulet detti av. Så hva gjør vi da, med 4 knekte hjulbolter på bilen, og verktøyet med besto av en 17 mm fastnøkkel, en dårlig flat skrutrekker og ei rørtang. Jo vi demonterer bremseskiva og prøver å lirke ut boltene, kalipperen er heldigvis 17, unbrakoen som holdt skiva var "heldigvis" knekt den også, røske ut brekkskoa, få lura inn rørtanga på innsida og få løsnet det med rørtanga, og lirke innover med trekkeren der det gikk. Glemte å nevne at jeg sto i begynnelsen av en lang nedoverbakke, og min bedre halvdel måtte holde bremsen underveis. En hel hjulbolt, en ekstra liggende inni, men ikke faen at jeg fikk løsna en på det andre bakhjulet. Fint at det ofte liger litt bolter i reservehjulsbrønner sier nå jeg, fikk i 3 bolter, korrekt plassert for best funksjon, og dratt til med en fastnøkkel. Nå er det tilkommet en bolt til og dratt til med hjulvinne skikkelig. Utrolig hva man kan få til med litt stahet og ståpåvilje. Quote
iNDiANER Posted September 18, 2010 Posted September 18, 2010 Det høres ut som det er noen som har MacGyver-evner Godt det ordnet seg til slutt, tør nesten ikke tenke på hvor galt det kunne gått. Quote
Einar Posted September 18, 2010 Author Posted September 18, 2010 Det vrlitt slik kjør til det rister mere, og håpe det går bra, og det gikk bra på kusehæret, og der ristet litt til jeg fikk fyllt 4 av 5 hull. Litt flaks, og litt erfaring da jeg faktisk er bilmekaniker. Quote
