Som noen sikkert har fått med seg var eg og handlet ny bil før jul  :D
Denne gangen falt valget på en S124 E280T i farge 199 med sort sportsline skinn.
Bilen er solgt ny i norge til et begravelsesbyrå på østlandet (NB: ikke likbil)
VIN WDB1240881F280559
Model 280 TE / E 280
Chassis 1240881F280559
Engine 104942 12 034071
Transmission 722433 03 449882
Order 0 3 555 49025
Approx. year 1993
Dealer Norway (555)
Interior (cloth) fabric blue+blue violet+pacific blue (002)
Paint
199 metallic blue-black (с 01.01.1983)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
236 special lamp switching - daytime running lamps (с 01.04.1985)
special light wiring for Norway and Sweden
240 outside temperature indicator (с 01.03.1982)
291 airbag for front passenger
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
341 additional lamp (с 01.09.1982)
420 automatic transmission, floor shift (с 01.01.1963)
440 tempomat (cruise control) (с 01.09.1975)
524 paintcoat preservation (с 01.01.1964)
537 mechanically operated antenna and front loudspeaker - without radio set (с 01.10.1989)
580 air conditioner/Tempmatic (с 01.11.1982)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
630 ECE warning triangle (с 01.08.1980)
668
673 high-capacity battery (с 01.01.1964)
812 rear-mounted loudspeaker (с 01.11.1974)
829
859 model update ii (с 01.01.1978)
910 14V/65A alternator
alternator with increased capacity (с 01.11.1990)
Grattis nok en gang Johnny :D :D :D
Bare holl deg unna brøyteklanter i rundkjøringer ,så du IKKE spinner stein og pigger på meg mer. Så er jeg fornøyd :lol:
Det begjynner vel og minke på piggene så noe mindre haglskurer blir det etter vert  :D :D
Dessuten skal en holde god avstant til bilen foran har eg hørt  :lol: :lol:
Oi oi oi sånn var det ja...!!!My bad :lol: :lol: :lol:
Nydelig bil!
Er det bare øynene mine, eller har denne uvanlig mørkt treverk i midtkonsollen? Var dessuten en uvant layout på knappene til varmesetene, litt mer "grisøyd" enn normalt? (Hvilket betyr at de sitter tettere enn normalt, for dere som ikke er vant med landsbygd-lingoen...).
MVH Tore
Treverket var veldig mørkt til å være zebrano, og det så veldig bra ut. Setevarmen er trolig ettermontert sammen med skinninteriøret, derfor bryterne sitter som de gjør, for ser ikke noe om skinnseter, sportsseter eller setevarme i utstyrslisten.. :)
Gratulere med godbilen da Johnny :D Fortsatt fornøyd eller? Har du funnet feilen med tomgangen?
Vart en tur på meg lille juleaften også, ble en 92 300TDT til, gamle bilen til E_S.
Mvh Arne
Er etter montert sportsline skinn med varme, tror ikke denne hadde varme orginalt  :?
Det som er litt rart er at når skinnintreøret blei montert så har dei bytta til zebrano tre og det ser ut til at dei har funne en midtkonsol som ikke fulgte med setene siden dei har lagt hull på feil plass.
Det står ennå nøttetre på instrumentbordet ser ut som dei har prøvd og få av disse for dei står og spriker i endene.
Men nå er det nøttetre til dørene på vei fra usa og resten har eg fått tak i fra 320en som blei slakta i dalen  :D :D
Nydelig bil!
MVH Tore
Fargen er nok vanlig zebrano så det er vel bildet som er feil.
Mvh Arne
Har laget meg en liste over ting som eg har lyst til og ordne opp i, så får vi bestille noen deler og ta en storjobb når delene er på plass.
Det blei altså ikke noe G?
Mvh Arne
Var det så gæli da? eller er det noe annet?
Jeg var i nord og kikka litt på den som var mest interesan men var så jevli rusta ramma på den, så jeg slo det fra meg, får spare til en nyere modell :D
Samme som med meg.. Hadde lyst på G, men konkluderte med at alt som var tilgjengelig i min prisklasse minnet mer om "elendigwagen" enn Geländewagen, så da slo jeg det fra meg og fant ut at jeg heller får få meg en W463 hvis jeg en gang blir rik.. ;)
Nei da bilen er bra den, men det jo alltid ting som eg vil forbedre på en bil uansett hvor fin den er!!
En psykolog har sikkert et fint ord på den sykdomen  :D :D
  • 7 months later...
